Home
Community
Discussion Forums
Most Active Hardware Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
the fifo buffers only go to 16/15 - thought it should go to 60 - should it?
mandrill1
Member
04-30-2004
04:17 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
We're trying to resolve an issue which on PCI cards in the past has been sorted by changing the fifo buffer sizes to 60. On the 485 PCMCIA card however the buffer size only goes up to 16 - is this correct?
0
Kudos
Message
1
of 2
(3,017 Views)
Reply
Re: the fifo buffers only go to 16/15 - thought it should go to 60 - should it?
Chris_Rake
NI Employee (retired)
04-30-2004
08:14 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Correct - PCMCIA FIFOs are 16 bytes deep.
1
Kudo
Message
2
of 2
(3,017 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
