viOpen (VB/C++) returns 0xBFFF0000 (VI_ERROR_SYSTEM_ERROR)
Hi
I'm having a problem where viOpen (VBA) to one of the PXI cards (there are 3-4 PXI cards) returns 0xBFFF0000 (VI_ERROR_SYSTEM_ERROR). However, using MAX VISA test panel is OK. I'm using PXIe chassis, and connect it to my external PC.
When I bring all the cards to another chassis with an embedded controller (PXIe-8101), no issues are found at all. All cards work perfectly.
Does anyone see any similar issue before?
(4,371 Views)
(4,366 Views)
