07-03-2023 02:15 PM
LV 2017 32 Bit
currently added regex functionality, works succesfully in development, but after a build:
Cause: regexp_32 is expected
2023-07-03 20_53_03-Extensions.lvlib_Load Extension from standard Location(s).vi Block Diagram on Mu.png
solution: manually copying these two dll's to the data folder in builds (while only the 32bit version would be used):
finally also the build works.
would be great to have handled it automatically
thanks in advance and anyway for this great implementation!
07-03-2023 02:37 PM
Thanks, made an issue
https://bitbucket.org/drjdpowell/sqlite-labview/issues/29/regex-dll-not-in-exe
