Ever want to drop a for loop around a chunk of code and Not have auto indexing created on all the terminals and have all terminals that you want to 'pass through' the loop be turned to Shift Registers?
Would you like something that acts like this? http://screencast.com/t/jGDycjpVm
Download the attachment and check it out.
Feel free to make it into a quick drop shortcut and post online.
It's not bulletproof and due to time constraints, not robust error checking.
Presumed operation
*Drop a For Loop around a chunk of code
*Select that for loop only
*Run Scripting command
***************************UPDATE***************************
An updated version which is made for Quick Drop Keyboard Shortcuts is available at
http://lavag.org/topic/16701-for-loop-pass-through-utility-cross-post-link/?p=102354
Enjoy
