LabVIEW Communications System Design Suite
Create FIFO timing violation
Hello everyone! I am working with 802.11 application framework and try to save all samples in frequency domain from frame to further processing. For that purpose I create a long FIFO wich is 65537 elements depth in top level FPGA.gvi near other FIFOs such as TX to RF FIFO and etc.
During the compiling phase a have an error caused by timing violation. LabView tolds me that in Create FIFO I have a Data Path Delay above 1.7 ns and I don't know how to fix it, because I implement FIFO in the same way as TX to RF FIFO which works well in current project. Does anyone knows the solution? Thanks for help!
(5,682 Views)
Hi Mr_Q,
Which target are you compiling to?
Could you attach a screenshot of the error and how you have the FIFO configured?
Did you add in pipelining after creating this new FIFO?
Shalini M.
Partner Development Engineer
Alliance Partner Network
(5,634 Views)
Thank You for your reply!
My target is USRP 2944R
I added a feedback node as a Pipeline befor writing to the FIFO. It does not work.
All screenshots are attached.
(5,619 Views)
Accepted by mr_Q
Have you worked through all of the recommendations from the following help page on Resolving Timing Violations on the FPGA?
Shalini M.
(5,591 Views)
Thank You for your help!
I'd read this manual on Timing Violations but it did not help me at first. Anyway, I solved this problem!  LabView told me that time delay was in Create FIFO function, but the problem was that I cannot Write and Read from FIFO in single clock cycle. When I use pipelining between Write and Read functions, it start to work.
(5,571 Views)
