LabVIEW Communications System Design Suite
[Feature request] Changing the y-limit directly in a graph
in the GUI, when using graphs, you can usually click on the ymin and ymax and change the values. This is not possible if LV decides to change which ticks on the axes are labeled.
It would be nice if the behaviour was consistent.
Nicola
(5,199 Views)
 Hi Nicola,
thank you for your Request. Since your post is a feature request and this is a forum to discuss difficulties and problems, I recommend you to post your request in the Idea Exchange Forum:
LabVIEW Idea Exchange - Discussion Forums
http://forums.ni.com/t5/LabVIEW-Idea-Exchange/idb-p/labviewideas
If your Idea is supported by the community and you get some Kudos, R&D will take a look and consider taking action on changing this.
Best Regards,
Gregor
(5,180 Views)
