LabVIEW Communications System Design Suite
How to edit "vi properties" for an object?
As a long time LabVIEW developer, I commonly add descriptions to items by opening up the vi properties and then adding documentation. However, I can't figure out how to do this in the Comm Suite. It would seem to be possible, as all of the examples and frameworks have descriptions for a lot of the objects.  I would want to add documentation not just to the vi's, but also to objects like clock resources, FIFO's, etc. I'm probably missing something obvious...
Thanks if anyone knows how to do it!
-Brian
(5,181 Views)
Hey,
You can document your VIs by going to the "Icon" pane and entering the description in the "Description" field at the bottom of the pane.
Britton C.
Senior Software Engineer
(5,161 Views)
