LabVIEW Communications System Design Suite
[Feature request] Resize terminal behind wire terminals
I noticed it is sometimes very hard to hit the resize terminal of a node, because disconnected wire terminals appear practically on top.
It is a bit easier, if you select the VI first and then try to resize it. In any case, you might want to consider allowing diagonal resize at the corners.
Nicola
(5,216 Views)
 Hi Nicola,
thank you for your Request. Since your post is a feature request and this is a forum to discuss difficulties and problems, I recommend you to post your request in the Idea Exchange Forum:
LabVIEW Idea Exchange - Discussion Forums
http://forums.ni.com/t5/LabVIEW-Idea-Exchange/idb-p/labviewideas
If your Idea is supported by the community and you get some Kudos, R&D will take a look and consider taking action on changing this.
(5,195 Views)
