LabVIEW Embedded
can't find blackfin embedded VIs!
so i installed LabView 8.6, then Visual DSP 5.0, then LabView Embedded for Blackfin. All installations completed successfully.  But then I launched LabView 8.6, and I can't find any Blackfin VIs!  Can someone help me?
Thanks so much,
noah
(6,165 Views)
Accepted by noahgrant
Hi Noah,
You're probably not targetted to your Blackfin board. If the VI you open is targetted to your computer, the Blackfin VI's won't be available because they can't run on a PC. You will have to create a LabVIEW project, add your Blackfin board as a target, and create a VI targetted to the Blackfin board. The easiest way to do this is from the Getting Started screen. In the lower left-hand corner, there's a Targets box, and you can select Blackfin project. This will bring up a wizard that sets up the project for you and automatically add an Untitled VI targetted to the board you select. When you open that VI, you'll have a Blackfin VI palette available. If not, then my next suggestion is restarting your computer if you haven't already so the installations will all be complete.
Let us know if that works!
Product Support Engineer
(6,148 Views)
