For example, I like to display numeric controls & indicators with the typeface right-justified & bold, and the display format set to floating point with the digits of precision set to 3. If I drop a numeric control from any of the palettes (classic, modern, silver), I need to do too many right clicks to accomplish this.
I know that I can create custom controls and put them in the user controls palette, but I think it would be nice to be able to grab the controls & indicators from the regular palettes already formatted the way I like.
This could be accomplished most easily (for the user) by allowing a right click option to use the current format for that particular control or indicator as the new default. Such that the next time a control is selected from the palette, it will already be formatted the way I like. Of course, this idea could be extended beyond the properties I mentioned, as well as to other controls & indicators (not just numerics). I imagine this could also be implemented through the Tools/Options menu.
