13 | |
11 | |
3 | |
3 | |
3 |
There are times that I wanted to use a numeric constant or control as a string data type. In order to use a different data type, I would manually copy and paste the control/constant values to another data type. Moreover, if the control or constant is an array of values, it's tiring to do a manual copy of the values. Creating a vi that would convert the data type would also take time. As a suggestion, I hope LabVIEW can include in their "right-click" property box a method of converting the Path to String, String to Path, String to Numeric and Numeric to String.
I don't know if this is a big thing or not. Just a piece of thought.
Any idea that has received less than 6 kudos within 6 years after posting will be automatically declined.
