8 | |
3 | |
3 | |
2 | |
2 |
Starting with channel wires makes me wonder why it requires a wire (besides by the technologies name that is) at all.
I would prefer it to simply use "terminals". Selection of the used channel wire by the terminal is done by passing a name similar to named queues. The channel wire itself is obsolete by that which would also conclude the discussion about "channel wire direction indication".
Usage of 'channel wire terminals' will be similar to shared variable nodes.
Declined for reasons listed by AristosQueue in the discussion thread
