6 | |
6 | |
3 | |
2 | |
2 |
Hi all,
When creating accessors, I find that 99% of the time my read and write accessors have the exact same documentation. I'm literally copying and pasting into the "VI Description" for each pair of accessor VIs.
For example:
Let's say I have a data member called timeout_ms.
Whether it's the read accessor or the write accessor, the documentation is, "VISA timeout in milliseconds for serial transactions." Entering it twice, while routine, has become mildly annoying.
Why not make the accessor documentation a property of the "Property Definition Folder" that houses each pair of accessors? That way, most of the time the developer would only have to enter documentation once.
How might this work?
The dialog might look something like this:
I'm a real stickler for VI documentation, and as much of a hassle as it can be, I document all of my accessors. Any time we can reduce the number of mundane steps to accomplish basic things, I'm very grateful.
Thanks as always,
Jim
