8 | |
5 | |
4 | |
3 | |
3 |
Almost every time when I'm building an application, I always have to reconfigure the created ini-file (based on labview.ini file) denpending on what to use.
Then I have to go search for the tags in labview.ini and copy them in my ini file.
It would be easier if you could hit a configure button in the application builder so you could select which setting you want to use in your own ini file and which one you don't.
I'm especially struggling with some standard ones like useLocalDecimalpoint
Any idea that has received less than 9 kudos within 9 years after posting will be automatically declined.
