Currently, in Array Functions pallete, there is only empty array constant. But, isn't it possible to add constant of numeric, boolean and string arrays also? Anyway, it would be faster then to add them to block diagram, than now. Empty array constant should stay for sure - b/c it's not possible to predict all possible array types - but such common arrays will be useful. It's like in case of Silver Controls - there are already numeric and strings array (but also - why not to add boolean array there too? What was the logic behind it?).
