If a probe window has to shorten a string due to window size constraints, it should add a "..." at the end to help ensure users are aware this is not the full string.
For example, the full line of one of the items in the array below should be something like: ni.var.psp://localhost/Untitled Library 1/Variable1.
The probe window should show "ni.var.psp://..." for clarity, rather than just "ni.var.psp://".
This probe shows a reference to a network published shared variable. It is retrieved by uncovering all the variables within a shared variable library. The code yielding that array is as follows: (the screenshot of the block diagram code for clarity)
