I would like to include arguments for any/all shortcuts from the installer. Currently you can build a labview installer to put shortcuts on desktop and to the "Program Files" menu. But there is no option to include arguments. See attached image of how it would look in labview.
This would allow for the installer application to include file path arguments into any executable. Example: You want to include a tftp server application for the installer and embed the tftp path in the shortcut.
It could also be usefull to run the same labview app with many startup arguments. Like if you have a debug mode and normal mode. If you want to include both options on the desktop you could use a -debug as the argument. And include it in the shortcut from the installer. Both shortcuts would point to <application> but one would also say "<application> -debug"
Thanks.
-Corey
