6 | |
6 | |
3 | |
2 | |
2 |
Hi LabVIEW users.
One of our customer would like to change Increment and Decrement Buttons' color programatically.
Although it can be changed using custom controls, it is more easy to change UI if the function is implemented.
How do you thinks?
Eisuke Ono
NI Japan.
Apprecation Engineer.
