Application Builder property dialog >> Source File Settings >> Customize VI Properties...
One property I'm really missing is "Allow user to resize window". Obviously it can be set in the VI itself but there is no way to overwrite this setting when building the application.
Any idea that has received less than 8 kudos within 8 years after posting will be automatically declined.
