| User | Kudos |
| 12 | |
| 11 | |
| 9 | |
| 8 | |
| 5 |
Currently there is no way to have a VI run automatically when a LabView Project is opened other than using a separate VI using VI server calls. I would like to see this added to the Project properties menu similar to the option that is given within a VI's properties-execution to "Run when opened". It would also be nice to have it target the correct device within the project.
National Instruments will not be implementing this idea. The command line approach is the preferred workaround.
