10 | |
3 | |
2 | |
2 | |
2 |
As of this quarter, the NI developers suite DVDs will only be sent out on a bi-annual basis. See the text in the current Dev Suite donwload site for the text on this (Dev Suite Download Site).
With that in mind, I forsee using the donwload links to get my Dev Suite updates more and more often and using the DVDs less and less.
What I am asking is that a better method be implemented to allow customers to download the software that they need. If you attempt to download any package from the Dev Suite download site, listed above, you must click through between 3 and 4 linked pages to actually arrive at the download link. Given the 46 packages on the page that is a minimum of 138 pages that must be navigated to download Dev Suite.
How about updating the downloader to allow selection of all of the packages you wish to download, press the button and the downloader will take care of getting all of the selected packages.
This downloader should allow download of particular versions of the software (i.e All packages that were released with LV2009 SP1 and the applicable drivers at that time). These should be "presets" that would allow quick identification of which drivers shipped with which version of LV.
Jim Kring had a related post (here), however I think that the two ideas are somewhat different
