8 | |
5 | |
4 | |
3 | |
3 |
I use disable structures and conditional disable structures more and more as my coding starts to spread over multiple targets (Host, RT and FPGA).
I like to include some debugging indicators for my code so that I can (with the proper conditional disable symbols set) debug my code more easily but still remove the bloat for actual release code.
What I have noticed is that controls and indocators which are disabled int his way are NOT accurately represented on the FP. As such I am surrently unable to determine by looking at the FP of a VI that perhaps half or all of the visible indicators are or are not actually being used in the code.
Even when the code is running, the controls and indicatory which are actually disabled are still visible (and supposedly still available over VI Server for example). I think these controls should be actually removed or at least have a visual indication that they are diabled on the BD (distinct to the appearance caused by writing to the "Disabled" property of the control).
The LabVIEW help states: "When compiling, LabVIEW does not include any code in the inactive subdiagrams of the Conditional Disable structure" but I question how true this statement really is.
Although these controls are DISABLED (Not present in the source code)........
Here they are.....
This raises issues on the FPGA level more urgently than on the PC side, but I feel the sentiment behind the idea is the same.
Of course things get more compilcated when the controls are connected to the connector pane, but perhaps simply prohibiting the presence of a connector pane terminal in a conditional disable structure would solve that problem.
Shane
Any idea that has received less than 6 kudos within 6 years after posting will be automatically declined.
