| User | Kudos |
| 11 | |
| 10 | |
| 7 | |
| 5 | |
| 4 |
Big clusters... we've all needed to work with them.
Currently, to change from one cluster element in a bundle/unbundle, clicking on the element name brings up context menus with the hierarchical structure of the cluster...from the beginning. Say you want to move to the next element in a cluster at a certain level, you have to navigate all the way through the hierarchy. You could drag down and then rewire and delete, but that's still more effort than feels right.
How about changing the appearance and functionality of (un)bundle by name so that each section of the cluster name is a clickable link. Clicking on it would allow me to browse the hierarchy at that level, so click on the last element (currently Port) would show me the following option:
There's only one option at this level at the moment, but if I were to do the same on the Laser Settings section, it would drop down a menu with All Elements, <redacted section>, Laser Marker Mode and Laser Settings.
