6 | |
5 | |
2 | |
2 | |
2 |
Problem:
When you want to have the organization of your files within the project file different from the folder hierarchy on disk you are not able to connect to a vi dynamically through vi server because you simply do not know the path which the builder has created within the executable.
To rebuild and maintain the folder structure of the disk in the project file is time consuming and error prone.
Solution:
A small tool which extracts the actual paths within the executable so you can copy the correct path to your vi-server call would do the job.
