6 | |
6 | |
3 | |
2 | |
2 |
When Open reentrant instances of a VI asynchronously the 2 methods that work are configuring the front panel to open when called and setting up a invovle node for front panel open inside the target VI. It would be helpful to have the option to open several front panel instances setting up the control of this behavior on the caller.
