8 | |
6 | |
5 | |
4 | |
3 |
When you have the Desktop Trace Execution Toolkit (DETT) set to log errors, it will indeed generate an entry any time an error is generated. However if any custom message data is part of the error it is not captured, the DETT instead displays the default text for the captured numeric code.
I propose that this data should be logged as well.
