As in the title the numeric representation of iteration terminals seems to be wrong in LV 64-bit. Why is it Representad by 32 bit integer. Doesn't it seem like a problem when iterating through VERY big arrays (size supported only in 64 bit LabVIEW) not to be able to track all of the iterations?
This is how it is now.
Should be 64 bit (no typecast)
Declined for reasons listed in AristosQueue's post on this thread.
