Closing an HTTP handle should stop HTTP functions (GET/POST/etc)
For example, in the above code, if the GET is taking a long time, the user might not want to keep waiting and hit the close button. The above code should skip the remaing wait and cleanly cleanup any refrences as needed.
Any idea that has received less than 3 kudos within 3 years after posting will be automatically declined.
