13 | |
7 | |
4 | |
2 | |
2 |
Hello all,
I've come to the point where I could really use a tool that compares LabVIEW classes.
This would basically be an adaptation of the "Compare VI Hierarchies" tool, except that you'd specify two .lvclass files and the tool would traverse the member VIs of the classes and compare them.
For example:
Essentially the same thing as compare VI hierarchies, except for classes. (NOT to be confused with comparing hierarchies of inheritance. That's not what I'm asking for.)
Would anyone else use this? I know I would. (obviously, because I'm asking for it. Maybe I am "asking for it" by asking for it.)
Thanks as always,
Jim
