If you bring up the contextual menu on a control, you can go to the Find menu item and search for things related to that item. Like, if there is at least one local variable, you can find local variables for that control by picking Local Variables.
This also works for finding the control's presence on the other side (front panel vs back panel), and Property Nodes and References and perhaps some other things. But, it doesn't let you find event handlers for that control.
It woud be very nice to be able to find the control's event handlers through this submenu.
Duplicate of http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Right-Click-on-FP-node-find-event-structure-cases/idi-...
