6 | |
6 | |
3 | |
2 | |
2 |
I'd like to have a way to give the FPGA on my PCIe card direct access to a block of the host PC's RAM. At the moment, the FPGA is limited to its internal RAM and whatever might be on the PCIe card. With my PCIe-7841, I have about 1MB available to the FPGA. If I need more, I have to use DMA FIFO transfers - the FPGA can use one FIFO to ask the host for some data and the host can send it to the FPGA in another FIFO. This is a lot of overhead compared with simply using a memory method node to access the FPGA RAM.
So how about a method to allocate a block of memory in the host's RAM that the FPGA can access directly over the PCIe bus with minimal involvement by the host. For simplicity, it will probably need to be limited to a contiguous block so that there are no gaps in the addresses - the FPGA would only need to know the start address and the number of bytes in the block. Ideally safeguards should be established to ensure the FPGA doesn't access memory outside the allocated block, but leaving that to the LabVIEW programmer would be fine.
