11 | |
11 | |
3 | |
3 | |
2 |
I have written and read code that sets Disabled property many times, and it always looks the same.
I wish I cold say the same thing with two nodes and one wire instead of five nodes and four wires. This is what I have in mind.
I am not attached to the name of the proposed property. I am partial to the Boolean data type and I prefer to go with positive language (enabled as opposed to disabled).
One alternative for naming is to use plain "Enabled" for the proposed property, and change the name of the old property to "Disabled Mode" or "Enabled Mode".
