I sometimes need to create Front Panels that are to be navigated by keyboard alone, which makes the tabbing order quite important. At this stage, I need to manually disable my error cluster controls otherwise they get included in the tabbing order list. Given my error cluster controls for any VI that shows its front panel will be moved out of the visible area, I need to ensure the operator cannot tab to them. Therefore, I would like to see error in clusters have their default Enabled State set to Disabled.
I don't think a change to the default enabled state property would cause any complications?
