6 | |
5 | |
3 | |
2 | |
2 |
I often pass an error wire out of a for loop. It auto-indexes, as most outputs of a for loop do, but I never retain the auto-indexing.
The current default behavior is:
But I think the default behavior specifically for an error wire should be:
