6 | |
5 | |
2 | |
2 | |
2 |
Expose a method to set the scroll position of the plot legend for graphs, charts, etc. I often want to operate on multiple graph sets containing multiple plots, (i.e. multiple files each containing multiple plots). I overlay these and align them for comparison. It would be nice to be able to set the plot legend scroll position so that the active graph set is visible in the limited screen space I have for the plot legend. I also typically use a Boolean array along side the legend to set visibility for each plot. If I could scroll the legend, I could keep things aligned and have to do much less data manipulation to track the other plot properties when I bring an active file set to the top of the list. An example GUI is shown in the attached file.
Available in LabVIEW 2013 and later
