| User | Kudos |
| 11 | |
| 10 | |
| 7 | |
| 5 | |
| 4 |
Add a new selection, so that the application pauses if "something" is on the wire...please see the attached image!
Similar to that, a conditional "DBL" probe could be enhanced by adding a "NaN" option...one could realize that by inserting "Equal to ... NaN", but it would be easier to just select this "value" with a checkbox, and two conditions could be monitored at the same time ("=NaN" and "=xxx")
