| User | Kudos |
| 10 | |
| 6 | |
| 5 | |
| 3 | |
| 2 |
GitHub is amazing.
Figured that deserved to be on its own line just to let it sink in to the importance of this idea. Version control is no longer something only used by professionally trained software engineers. It's here for the masses; for the graphical design artists, animators, document writers. GitHub has a really cool web front-end to version control and brought sanity to DVCS (maybe bitbucket deserves some credit as well). It has championed a simplistic work-flow via pull-requests: GitHub Flow. It supports Issues for reporting bugs or other issues, and has an assortment of other collaboration features that make GitHub amazing.
GitHub (I don't mean git) integration with LabVIEW would demonstrate the power of Graphical Programming to the world.
Again, let that one sink in. There are 3 tenants of GitHub integration that LabVIEW must achieve:
1) Display the image of the block diagram and possibly front panel on GitHub when viewing a repository. Isn't it embarrassing that JKI State Machine Objects has to resort to putting images of VIs in the repo because GitHub can't render the VIs block diagram source?
2) NI must give away graphical diff and convince GitHub to run it. GitHub shows diffs on the web; Source Tree shows diffs in its tool. It's decision circa 1990 to not give Diff and Merge away with the basic version of LabVIEW. To think of diff/merge as advanced software engineering tools is a thought stuck in the past. LabVIEW needs its graphical diff shown within GitHub on a source file's history.
As a side note, vote for a version agnostic Diff/Merge idea here.
3) VI merge needs outstanding auto-merge capability that is built into pull-request merges. When creating a pull-request on GitHub, you'll see this statement (possibly), "Able to merge. These branches can be automatically merged." To work well in a DVCS multi-contributor, possibly open-source environment, the language needs superior auto-merge capability. Pretty much all other languages get it for free because they are text.
Keep in mind that NI will need a partnership with GitHub to accomplish this; however, this type of thing is not unprecedented on file type (maybe unprecedented with a proprietary langauge...). Just take a look at GitHub's ability to Render and Diff Images and GitHub's ability to Display Jupyter Notebooks (formerly IPython Notebooks).
