Have the ability to select Text or HTML for the message of an E-Mail.
Current version of Labview you can only do text.
There is a knowledgebase article that provides instructions and a download for doing this.
How Do I Send HTML Emails Using The SMTP Email VIs in LabVIEW?
http://digital.ni.com/public.nsf/allkb/D1EDC02799EBE3CB8625705B0056B646
That is correct, I can fix the problem but it would be nice for NI to fix the problem so when you upgrade versions of LV you do not need to copy any extra vi's.
