Taylorh140
Hide .lvclass extension on property nodes
Status: New
Why all the redundant .lvclass everywhere? Please remove this from the property node, it makes the property node longer than it needs to be.
12 Comments
GregSands
Active Participant
It's already possible.  Go to the Class Properties dialog, and on the Documentation page, set the Localized Name.
Taylorh140
Wow, this makes me happy!
perhaps the default in the future would be to remove the .lvclass?
crossrulz
Knight of NI
Wow, that even works for the terminals when creating a VI in the library!  This makes me a happy person.
Darren
Proven Zealot
I'm kudoing this in the hopes that we can get the default behavior changed in a future version to set the localized name by default to be the class file name minus the .lvclass extension.
IlluminatedG
Active Participant
And same for lvlib plz! Currently doing that manually for every library/class I create.
~ Helping pave the path to long-term living and thriving in space. ~
Darren
Proven Zealot
Why do you do it for .lvlibs?
IlluminatedG
Active Participant
Places like this and anywhere else the FQN is displayed by default
Darren
Proven Zealot
The context help still displays the ".lvlib" extension even if you change the localized name of the library. Is there some other place in the editor where you see a display change when changing the localized name of a library specifically to remove ".lvlib"?
IlluminatedG
Active Participant
Well ignore me, I could have sworn it showed up in class terminals and such but it definitely doesn't so I'll just have a mental crisis for the rest of the day.
Darren
Proven Zealot
Ah yes, you're right. If you have MyLib.lvlib:MyClass.lvclass and you've changed the localized name of both of them to remove their extensions, then when you drag the class control onto the panel it will get a label of MyLib:MyClass.
