I'm making Icon Templates out of the styles of icons I use most, and discovered it would be very useful if I could create a template and change one glyph layer for each template.
In the example below, I could load the Q Ref template, quickly remove the Q Ref layer and replace it with another control glyph.
I do realise I could just select the pink box and delete, but not all glyphs are nice easy to selct shapes and sizes
The templates with layers should be seen with the other templates, but when selected, recreate the individual layers in the layers tab
National Instruments will not be implementing this idea. We are not planning on making any changes to the way template icons are stored for use with the icon editor.
