6 | |
6 | |
3 | |
2 | |
2 |
Creating a function palette i noticed how horrible the current system is, why can i not:
- R-click and activate scrollbars
- Resize palette window (i have to programatically change the .mnu file to change palette layout)
- Drag'n'drop functions
- R-click and sort functions (i have to programatically change the .mnu file to change palette layout)
- Insert rows
- Insert columns
- Reedit icons (although i use the new editor it gets flattened so if i want to change the icon afterwards it's an old style flat one)
- Get automatic/linked icons (e.g. say "Use icon from this .class file)
I'm sure there are more improvements to be done, but those are from the top of my head.
Basically it should be/work like a normal window and a normal array.
/Y
