| User | Kudos |
| 14 | |
| 3 | |
| 3 | |
| 2 | |
| 1 |
I've been recently experiencing issues with memory running LabVIEW 32-bit under Windows XP 32-bit. One potential solution was to swap to LabVIEW 64-bit running under Windows 7 64-bit, but unfortunately I need either NI-CAN or NI-XNET driver support which isn't currently available. Luckily it looks like running the 32-bit application under Windows 7 64-bit overcomes the immediate problem but I worry that this involves compatability interfaces (not that I don't trust Microsoft of course).
LabVIEW 64-bit has been available now for approaching 4 years and it would be nice to see a full suite of modules for the 64-bit in line with the 32-bit version. Failing this a timeline of when they're likely to be delivered would be useful - the only answer at the moment seems to be don't know, which doesn't seem very professional!
Could I ask the LabVIEW R&D team to at least consider publishing a plan?
