| User | Kudos |
| 12 | |
| 10 | |
| 6 | |
| 5 | |
| 4 |
It would be necessary to insert an alert when opening .vis made with different versions of LabVIEW than the latest used. "This file has been created with LabVIEW 13. Current version is LabVIEW 15. Do you want to open?" Y/N I work with at least 4 different versions of LabVIEW and sometimes happens to open a project (and to work on it for hours....) with another LabVIEW version, without noticing the automatic upgrade. Then time for downgrading again. Thanks
Duplicate of https://forums.ni.com/t5/LabVIEW-Idea-Exchange/Wrong-LabVIEW-version-alert/idi-p/2495594
