When working with large resolution monitors 2560 H pix in a dual monitor system 5120 H pix it would be great to be able to change the cursor type and size (similar to Autocad...large crosshairs) for alignment of objects. The BD and FP grid system makes it to hard to see small lines and clutters the diagram. A zoom on mouse scroll wheel would also be a huge improvement for work in the block diagram.
Duplicate of the following two ideas:
http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Change-Increase-Cursor-size-within-LabVIEW/idi-p/17326...
http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Add-a-zoom-function-yes-I-said-zoom-So-sue-me/idi-p/91...
