| User | Kudos |
| 13 | |
| 11 | |
| 6 | |
| 6 | |
| 4 |
Using 2023 for the first time (skipped 2021 and 2022)
QuickDrop used to be quick.
It was very convenient.
Now it takes a second to load.
That's pretty inconvenient if you're trying to... do much of anything.
Best example: If you're trying to remove code (Quickdrop's Control-R), now instead of quickly removing the selected code, you get to deal with accidentally RUNNING your VI (Menu's Control-R)
Please make it Quick again
This was a bug in LabVIEW 2023 Q3 (reported to R&D as Bug 2468882) and was fixed in LabVIEW 2023 Q3 Patch 1.
