10 | |
3 | |
2 | |
2 | |
2 |
Certain keyboard shortcuts are standard across operating systems and applications. When doing text entry, LabVIEW implements ctrl-c, crtl-v, and ctrl-arrow keys for text selection and manipulation, but does not allow ctrl-a. I have implemented this for string controls.
I would like to see this be the default behavior for all text entry.
In LabVIEW, ctrl-a currently selects all objects on the FP or BD. But when the cursor is in an active text field, ctrl-a should select all text in that field. This should include strings, tables, graph labels, control labels and captions, numeric controls and indicators, free labels, and so on, and should work in development and at runtime.
