3 | |
3 | |
2 | |
2 | |
1 |
The Property class, which represents the property node, has a property called All Supported Properties which ideally would show all the properties supported by the class the property node is linked to.
The problem is that it doesn't. If you have nested properties which come from another class (for example, the properties for the caption which can be selected by opening the pull right menu, as seen in the top image), those properties aren't returned when you call the property, and instead you just get the property for the caption reference, as seen in the bottom image, where the ControlIndex property is shown immediately after the Caption property.
Instead, I want either this property or a new property to return all of the nested properties as well, just like you get in the UI.
This would be useful for setting properties using scripting and alternate UIs (like this one or this one, which can't work today, because they can't get the full list of properties).
