| User | Kudos |
| 1 | |
| 1 | |
| 1 | |
| 1 | |
| 1 |
Make the Panel Resize event in the event structure a filter event. This would allow for clean, professional looking control of VI panel size. Use cases include: limiting the maximum panel size, preventing a panel from resizing in one direction, only allowing the panel to resize in discrete increments, etc.
In traditional windows programming, filtering the WM_RESIZE event is often used to control window size and I'd like to see this same functionality come to LabVIEW.
Ideally, this change would include a Discard? option as well as NewBnds and Act as options in the Event Filter Node. Setting NewBnds or Act would allow the programmer to amend the resize before it takes effect.
