13 | |
8 | |
3 | |
3 | |
3 |
Currently the fastest way to insert a Bundle By Name node into an existing cluster wire is to use the QuickDrop Ctrl + I shortcut.
Holding down a modifier key (Ctrl, Alt, Shift, or a combination of these) while double-clicking on an existing cluster wire would be even quicker.
Notes
