7 | |
6 | |
2 | |
2 | |
2 |
i have faced this problem many a times. Suppose I have a main VI opened and if I have a subVI (say sample.vi) in the main VI and I try to open another VI of the same name as subVI , then the subVI in main VI will get replaced with the second subVI. Labview should take care that any VI should be referenced with the complete path and just not the VI name.
